Viewsat platinum DiSEqC/LNB problems
Username: Viewsat
Hi guys
I just got my viewsat reciever and I am having problems getting both the 119, and 110 to be viewed similtaniously...
-I have tested both dishes individually and they both work properly
-I have the appropriate DiSEqC settings for each LNB input.ie/119 to LNB1, 110 to LNB2
-I have configured my antenna setup to have each dish to the appropriate port.
and still I can not view the 110/119 similtaniously. I read briefly in another thread about having the same LNB for both dishes or it will not work, can someone please eloborate on this or any other suggestions that can help me with my problem
Thanks in advane
Username: Jdq
Post Number: 100
I and I see others with same problems, I can get them both working sometimes for a short time,Ive changed diseq,still same(digiwave 7000)One guy had same problem and got a DP34 switch and it worked.Its happened since the new Nag 2 bins came out.
