I just flashed my receiver, need a little help plz
Username: Inferno_20
I just flashed my pansat 2700 with a bin someone posted on this forum, I turn the box on and it has the menu for lanuage selection and I cant select the parental control menu, it is like whited out and unable to access it? I reset my receiver to factory default before I flashed it just now, so how do I access the parental control now when its not selectable?
Username: Spank
Post Number: 242
Do you have a channel list loaded? Or have you scanned yet? Try that and then see if you can get into the Parental menu.
