New member Username: CooljohnnyGuelph, Ontario Canada Post Number: 4 Registered: Nov-05 | my fta now wont power up is this because i put the bin over the firmware i dont know what i did im a newbie please help |
troy2388 Unregistered guest | awwwp jtag time |
troy2388 Unregistered guest | what bin or stb did you use? |
dssjunkie Unregistered guest | Open garbage, get rid of it, go to ebay and buy a Views@t or P@nsat you will not be disapointed! |
New member Username: Fox_20_12Post Number: 9 Registered: Sep-05 | similar problem with a friends c-sat,went dead with superbin2,5 other work fine. you can reflash it to the old superbin or the 134 bin, by forcing a download to the flashchip.turn stb off,get your stb tool ready and ready to push start,turn on the and immediately push start-do nothing until it finishes. do not put superbin2 back on-it will make the box go down again. maybe this box is a knock-off?? any help please??? |
Unregistered guest | where can i get a download for the nagravision 2 file i really dont know what i am doing i just bought it and its ready to be programmed i got it from satcyber and now i go there to get the files and it wont let me log in i sent them emails and no reply can anyone help with telling me were to get a file or what ever i need to do i just want free tv lol i have a cool sat 4000 pro and the stuff to hook it up to a pc just need the info and how to or were to go to get it i think i got ripped by satcyber please help thank kevin |
New member Username: Fox_20_12Post Number: 10 Registered: Sep-05 | SOME MUCH BETTER SITES, W -CURRENTLY UPGRADING,TRY IN A DAY OR SO YOU WILL HAVE TO REGISTER |
Silver Member Username: SpankPost Number: 236 Registered: Oct-05 | Kevin, Check other threads in the future, your answers are there: These were both posted in a thread titled "ALL C00LSAT user read here": and you don't have to wait a day or so, to get them. |
kevin 83245 Unregistered guest | Thanks for the help i will give it a try thanks agian kevin |
