PANSAT bin file update
Username: Vlemar
Mississauga, Ontario
I know very little about FTA stuff. I got a PANSAT receiver from a local shop and all I had to do was to connect to TV and it worked like a champ. A couple of days ago I lost all the channels. The guy who sold me the receiver has sent me the latest bin files for PANSAT 2700A along with loader software.
I am using straight thru rs232 9-pin cable to download the file as per the instructions provided. The download fails. I don't see any activity on the progress bar. I used COM1 port to connect the cable.
Can someone help me fix the problem.
dssjunkie
What instructions are they?
Username: Dbupkso
You have to use a special 9 pin cable. Which call Null Modem cable and the guy who selling you the Pansat should include that for your convenience.
I have a Pansat 2700 too and the bin file expire recently. Can you send me the copy of the bin file too. Thanks!
Username: Satone
If anyone has the new pansat 2700a bin file can you email it to me thanks. satone2@hotmail.com
Username: Vlemar
instructioons reg the use of loader program -
Username: Satone
Did you follow these procedures.
-Connect the 9 pin cable between the receiver and PC.
-Turn the receiver power ON.
-Open the GTRom Loader V3.35 (Pansat 2700A).
-Click BIN FILE and select the Bin File to be downloaded.
-Select FILE TYPE (api) and click Download.
-Do not interrupt the receiver power while downloading.
-Press OK after Download Complete!! appear on the PC screen.
Username: Satone
Hey Dbupkso this place might help.
http://forums.koreanf2a.tv/showthread.php?t=8805
