Need some help
Need some help
already download bin for a fortec ultra and
not all channel showed. My satellite doesnt use a diseqc switch and Im not sure if this is causing the problem. Can someone explain me how to correct this problem.
LNB type: dish pro, using two Lnb, quality 85, strength 99%, looking for 119 and 110, bin used 282t3 (posted 11/7/05)
It reads in antena setup lnb standard, lnb local freq 11250, 22khz off, diseqc tone b, lnb power reads on, tp 12224v20.000, positioner setting disable, satellite scan fta
Thanks
