Channel List for 119' are messed up on my END
Username: Barangay
Detroit, MI U.S.A
Post Number: 15
Hi All, I have the C00lsat 4000 and downloaded the new STB FIX (NORW20051108 and everthing works BUT I notice something after I checked channel listing for 119' satellite.
Problems.
1 2 Local Channel
2 4 Local Channel
3 5 Local Channel
4 7 Local Channel
....and so FORTH....
239 8800 CHANNEL
THEN
240 WDBJ
241 KVTH
242 KVLD
243....and so FORTH
547 ETC3
The 1 to 239 all SAYS SCRAMBLE
wherein all the 6 HBO, 4 SHOWTIME, 4 CINEMAX
are all SCRAMBLE
Then 240 to 574 are all open but there's only 2 available HBO (HBO Latin and HBO COmedy, 2 SHOWTIME ONLY - SHOWCS and SHOWBYND..These are the channels available from 110' but showing on my 119'
Prior to this when we had the BLACKOUT I ran the BLIND SCAN, Could it be got messed up when I ran the BLIND SCAN?
I am using the TWIN LEGACY (DISH PRO) that has 110 and 119 outlet and the DISSEQC 1.2 switch but right now I'm only connected to 119' since I having hard time putting them together it wont come out at the same time, so I took the DICSEQC for the meantime but my 119 is meesed up.
PLease HELP and advice. THANKS TO ALL OF YOU
