Pansat 2700A help
Username: Inferno_20
Hi I'am pretty new when it comes to updating the pansat for it to work. I have a standard 9pin and 9 hole cable and bought a gender changer so both sides are female type. My problem is when I select the bin and hit update with my pansat receiver on and connected to my pc through the com port it will still not update it and its like the pc is not communicating with the receiver. Any help would be appreciated. I am using a pansat 2700a, gtrom loader 3.35 and I already reset the receiver back to factory settings.
Username: Z28haze
Windsor, On Canada
Sounds like your cable is crap, spend some money and get the proper cable
Username: H3lt3r_sk3lt3r
Post Number: 474
@John Anderson
What you'll need is a cross-over rs232 f to f, not straight-through.
hi i need help with my 2700a pansat its not booting up and i would like to know what or where could i go and get the boot file or how to make it work
Username: Spank
Post Number: 230
Pansat 2700 fix
Register for free to get the file.
[link removed]
