Directv access card dump
Lostinspace
Does anyone know how to dump a Directv Access card? Mine is full and I would like to dump it so we can get more movies.
Username: Thill1951akalk
Post Number: 820
Call DTV and ask them..they are very helpful...LMAO
killerthiller
hahahahahahahahahah
lol hahah omggg
10$ says he calls dtv!!
Username: Thrill_is_gay
yea...put the card in your mouth...and then swallow it and wait about 8 hours and you will have your newly dumped DTV card...what a fcuking idiot stick...ROTF
Lostinspace
It was nice to read that 3 idiots responded. You can send the $10.00 to some charity. I had a bet that no one would have an answer. Thanks for making me a winner. Lostinspace
Post Number: 9
you're not a winner...you're a fcuking jerry's kid who needs to get a life...does this pic bring back memorys you fruitcake...ROTF
Lostinspace
To: Thrill . Nice to see you have posted a picture of yourself. However I must say you are sure ugly. Maybe you had better keep the $10 and make a down payment on some plastic surgery. Also getting an education and some lessons in manners would also help you. You can also notice I do not have to use swear words to express my self. By the way it is time to take you mother to the groomers.
m1nd
If it was so easy to dump the card it would have been done long ago.
Glitching is the concept of varying voltages to the pins to 'glitch' the card into giving a dump.
This is the main problem.
Well that and getting to certain aspects of the card that are really cryptic.
Username: H3lt3r_sk3lt3r
Post Number: 689
@Lostinspace
"I had a bet that no one would have an answer. Thanks for making me a winner."
That is such a N00B response, you're a winner everytime you ask a stupid question.
What's next, people will dare each other to answer a question, get a life.
Foundinspace
You can get a clean card for about $20 to $30. Call DTV like trill1951 said, but instead of talking about the card, just tell them your receiver is broke, and see what it takes to get a new one. An alternative is to go to best-buy and get a TIVO. Activate the TIVO and when they ask, tell them it's to replace your existing receiver.
Just don't ever say the word "card" while on the phone to DTV, and you'll be okay.
dumpfinder
I heard the dump was hear.
www.satreactor.com
Username: Thechiz2
Mars, Ur anis Mine
Post Number: 78
send me 100.oo dollors i'll dump it for you
ElectroKuesion
I use a magnet, a couple neon sign transformers, and a AFPHD (alien foil protective helmet device) to reset my card. But you have to make your own AFPHD because the ones sold on Ebay seem to be defective.
