Need help with Azira reciever
Username: Lebpimp88
Mississauga, Ontario Canada
my reciever got cut off, its over the air and i was wondering if anyone has the code for it amd/or knows what to do to get it back???
ariza 750cx
ariza 750cx
1) Go to menu
2) Go to Parental controls
3) Select Second Pin
4) Type in 0000 (default pin)
5) Select default key
6) Then select nagravision
7) Use volume up until you see "Dish Network" at the top (I think you'll push volume up 2 times)
8) Channel down once to select "key number"
***While on KEY NUMBER
***YOU MUST PRESS RIGHT, RIGHT to get to NAG 2
***Postion 1 is dish key 00 NAG1
***Postion 2 is dish key 01 NAG1
***Postion 3 is dish key 00 NAG2
***Postion 4 is dish key 01 NAG2
9) "key number" 00 should be set to: F2 98 74 44 1C 65 77 D8
"key number" 01 should be set to: 17 E3 E1 1D 89 4E 53 45
10) press ok (VERY IMPORTANT)
11) press exit all the way until you get back to watching TV
d-onion
Is this the same process for Ariza 700?
Thanks
