Need some help
Need some help
already download bin for a fortec ultra and
not all channel showed. My satellite doesnt use a diseqc switch and Im not sure if this is causing the problem. Can someone explain me how to correct this problem.
Thank you
Username: Slo_hand2
Post Number: 217
need to provide more info on your setup.
What type LBN
how many lbn's
are you using proper wiring?
are you getting quality and strength
what sat's are you looking for
were you up before and jst need to update the bin?
LNB type: dish pro, using two Lnb, quality 85, strength 99%, looking for 119 and 110, bin used 282t3 (posted 11/7/05)
It reads in antena setup lnb standard, lnb local freq 11250, 22khz off, diseqc tone b, lnb power reads on, tp 12224v20.000, positioner setting disable, satellite scan fta
Can anyone help me by telling me what bin I need for a "Eaglestar" receiver? is it a clone for Pansat or Fortec?
