Not getting all channels after scan
Username: Asifalam
Hi,
I have 121, 110 and 119 but when I do "power scan" I'm not getting all the channels that should come. some are missing.
also when do power scan after deleting all the channels I get a lot of duplicate channels.
should I do power scan or normal scan?
what is the difference?
also what's the difference between ALL and ALL+D
any thoughts!
thanks.
Asif.
Letmeon
I had this problem also. Don't know "D" means, but did normal Satellite scan and ALL+D. got all channels....trial and error. But it worked !!!
