No signal -help please
Username: Jderek
Post Number: 28
I've been up and running a Pansat2500 for over a year and yesterday when the kids turned on the receiver it says no signal. Any advice what I should check. Is there anything on the remote they could push that would make it read no signal yet everything is set up as it was on Monday night?
Thanks for anything to look for. DJ
Username: H3lt3r_sk3lt3r
Post Number: 117
Check the connections from lnb/switch to receiver.
Username: Reck1ess
Post Number: 8
i got the same problem and i check the connection. still no signal, only level. and the level is in the low 30's%
Username: Spank
Post Number: 181
It sounds like your dish isn't aligned properly.
You can try these sites:
[link removed]
http://www.hollsco.com/Products/SatCalc/
http://www3.telus.net/rampage/skew.htm
http://www.remotesat.com/lookangle.htm
