Pantec Ultra
Username: Tan
Montreal, Quebec Canada
Does anyone know about pantec? who could give me information cuz my satellite doesn't work well. can anyone help plzz
Username: Spank
Post Number: 28
What model of Pantec do you have?
Username: Spank
Post Number: 29
I am assuming it is an MX.
Just flash the Pansat 2500a factory bin on the unit then flash it with X85BL_050926_256t_api.bin
Make sure you Set Default Keys in the CAS section after you flash - for the channels to work.
These files are available at www.pantecdvb.com just scroll down to Pansat2500 section.
Username: Tan
i dont know it just says that its an pantec ultra multistar
help me help u
just follow the instructions that Spanky gave you above
