MULTI-STAR RECEIVER
ROCKDOG
I have a Multi-star receiver ms-2500pf
(QUESTION)-Is this a clone?
(QUESTION)-Is it made by Pansat?
(QUESTION)-Where can I get n2 for it?
(QUESTION)-This is the second time I asked
for HELP, Don't everyone HELP, please not all at
once!!!!!RIGHT.
(LAST QUESTION)-Is this sight for helping each other or do I have the wrong place?
Helping Hand
Answers in order of questions:
Yes it is a clone.
No it is not made by Pansat
you can get N2 bin from Al7bar. tk
ROCKDOG
Thank you very much for the help. I went on
al7bar.com But I did not see a n2 for this
Multi star receiver. I found the bin file for my
lifetime ultra, but nothing for Multi-star!!!
(QUESTION) I believe what you say is true,But
what should I be-looking for! Would you name the
file for me or where I could read about it. Thank You.
azzoooooooooooooooo
question rockdog-U want someone to help U out???
ANSWER-WHICH WAY DID U COME IN!!!!!!!!!!!!!
(he-ha-he-ha-he-ha-he-ha-he-ha)
Rock N Roll Dog
Go into this site
http://ftacentral .com/
Goto Pantec folder
Download: Clone_fix_050924_255c.bin
Good Luck
Rock N Roll Dog
Oh yeah....
Flash it with an original Pansat2500 bin before you use that bin listed above.
ROCKDOG
-Thank you for the INFO. But can you please tell
me why I have to flash it with a Pansat 2500 bin
file first. Again I know this is a clone but
what does it have to do with Pansay?
Rock N Roll Dog
You need to make the unit a Pansat 2500 by flashing it with Pansat's firmware. It won't hurt your unit at all, it just ensures that the N2 bin will work on your receiver. The n2 bin is for Pansat 2500s so it needs to be loaded on a 2500 not a multistar.
ROCKDOG
This is rockdog thank you very much for your help
and I will do it and let you know how I made out.
Hi,
I was told to use Clone_fix_051001_256c_V3.bin for the Multistar. Is it true?
Hi,
If U were told 1 thing by someone here and another by someplace else,U should have asked the someplace else "why". Don't come back here asking,is the someplace else correct!
Username: Thill1951akalk
Post Number: 11
This is safe and does currently work well..it is located at www.dsscommunity.c om File Share FTA area.
Pantec ms n2 92505 with bin.zip
(size: 1454.9 KB last modified: 09-28-2005 )
N2 281 slow Pantec MS/Pansat 2500a clone working Full Flash/working EPG/PPV+p*orn
Tom Jo
Hi
I do have a Pantec with n2 bin on it.
i am using 119,I still have problem with Xtasy por*n channel(it keeps freezing every 10 seconds).what can i do to fix it.
one more thing,
I can not get any info when I want to use EPG.
does anybody knows if i can have my EPG working?
dssjunkie
Does anybody know if c00lsat 4000 receivers are any good or finding bin files easy.Also what clone is it Pansat or Foetec thanks boyz!
Username: Jdq
Post Number: 93
C*olsat 4000 very good
not a clone
Any site will have files
dssjunkie
Thank You!
