2700a goes on and off, help.
2700help
For some odd reason my 2700a started going on and off continuosly last night and it would not stop, this happened approximately 2 days after I flashed the box with BL's latest bin, I did flash it back to the factory bin, but the problem persits.
Does anyone have any ideas on how to fix this before I call the Panarex and possibly send it in for repairs.
Username: Slo_hand2
Post Number: 120
is it a 2700 or a 2500 and if it's a 2500 is it a true pansay or a knock off?
2700help
dude I'm not that n00b status, I think I can read :-), no but seriously it is a 2700, I got it working now, it wasn't due to the bin file, the solution was kinda retarted, I pressed and held the channel up/down button on the box and the problem went away, what I did was I just stuck a little piece of paper in the hole between the button and the faceplate, so the channel up button is always on and it works fine now, except that the 3 buttons on the box are disabled.
