Posted on Hi, I was just wondering if you need a scart adapter for dreambox 7020 to work in north america? Can I use the regular RCA? |
Silver Member Username: Maple_leaf
Post Number: 837 Registered: Apr-05
Posted on Yes you can. the scart is just for adding more outputs. |
my2cents Unregistered guest |
Posted on scart adapter is for HDTV output. |
Posted on so you do not have to buy a separate scart adapter in order to get the dreambox set up and working? hdtv? I thought no receiver supported hdtv yet |
Post Number: 838 Registered: Apr-05
Posted on They don't just simmulated. Helps picture work better on HDTV's |
