Yes be sure to write the original bin from PANSAT first i do it 2 times to make sure flash is clean then write the new bin then your favorite channal list
dtvkid
On the pansat clones load which flash first? before the new fix
YES IT DOES YOU GET ALL CHANELS..( EVERY THING ) ILL LET YOU KNOW IF IT BLOWS THIS RECIVER.. I DIDNT HAVE TO LOAD ANY OTHER FILES JUST DOWN- LOADED THE BIN.. DIDNT HAVE TO RELOAD CHANEL GUIDE
LK/chicago
the only thing that is going to blow is your mother you stupid fcuking red-neck...
slicee
what bin is this ..? please post so we can d/l it here
Raimundo
Are TenX and PrivFant works for you guys, mine does freeze when 5 seconds on those channel.
fsfta
yes this bin works.. you can thank the team at http//www.fsfta.com for a super fast first delivery of the file.
they were the first one to release it.. and they are totally free. check them out.. lots of answers.. lots of files..
www.fsfta.com is the place to get fta files..
no1b4me
works, works almost perfect... confirmed by moi
getting a bit of freezing, freeze is short lived but freezing a tad nonetheless... not perfect but very good...
better fixes coming in the future should resolve this issue I would imagine
works just tits on pansats and clones... no worrys there gets all channels, sports PPVs, be sure to block the nasty ones from the kiddies...
no problemo... write orginal pansat bin then write the slow ecm bin and you will watching TV again...
If only they had a fix for Dave for the fortune of receivers and P4 cards sitting out there idle collecting dust... c'mon NDS, spring a leak, don't you want to sell more cards =) Even a BEV fix would be cool for variety sake =)
can anyone confirm if this bin works with the skyview 500? it's a pansat 2500 clone
Yeah ramundo I get the same thing on those 2 channels. it works for 20 secs, freezes for 20 secs, then works for 20 sec then freezes etc. Can only watch them at intervals, very annoying. Does anyone else get the same thing? Why does everyone else say everything works perfectly?
