Heat Issues W/new bin?
Username: Slo_hand2
Post Number: 107
Has anyone experianced any heat issues with the new bins?
I read on another site that the new Bin may be causing heat issues with Pansats and maybe other systems as well.
The suggestions given were:
(1) heat sink
(2) another fan
I felt my system and although not hot by any means seems to be a little warmer then before.
This is just a heads up for a possible (Note Possible) future problem, and might be worth checking out.
keyisme
my fortec on 24/7 nice and cool
my fortec is running cooler with 281 then it was with 279bin
kool
poor some nestly ice tea on it and it will run on a cool mode.
Username: Slo_hand2
Post Number: 110
THIS WAS ONLY MEANT AS A HEADS UP FOR A POSSIBLE PROBLEM, NOW OR IN THE FUTURE.
JUST PASSING ON INFORMATION WHICH IS ONE REASON THIS SITE IS HERE, CORRECT?
DON'T KILL THE MESSENGER!!!
Username: Jdq
Post Number: 75
With first N2 file I couldnt get 119 in without freezing on digi 7000 ,chip was very hot I put heatsink in and channels came in fine.With new file running fine dont know if heat sink helps.
USSR
I was up-grated of my Lifetime Ultra a few months ago after its purchase. I was put a heat sink with thermal paste from old CPU on the processor and small one with screw on the voltage regulator IC. These components were hot and can fail in the future.
