Ppv channels
bob21303032
pride fighting championships is on tonight and i cant get my ppv channels to work. the signal and quality are good but theres a black screen and it says scrambled or bad channel.What should i do?
dish guy
those channels are have moved to nagra 2 tht's y ur gettin the black screen !!
You are experiencing the same fate all of us NHB fans/FTA owners have come to recognize as the switch to N2. I did read the Playa by Play results at www.Sherdog.com if you would still like to get the results. Here is to a speedy fix in the Dss community.
