Multistar Pantec Ultra HELP Please
Username: Barryh
I recived my pantec plugrd it in and for a day or so I got 100+- stations.
The next day not a thing.
I have tryed to down load several programs. but all seem to be in a bin file that I can not open So I think the first thing I need help with is to open a bin file and then the best down load for my reciver. Please Help. Barry
Shan12
I have lost all my asian channels from nimiq 1 .Anybody have any idea . thankz in advance
chicago
gone to N2
Username: Calboy
Post Number: 12
"I recived my pantec plugrd it in and for a day or so I got 100+- stations.
I have tryed to down load several programs. but all seem to be in a bin file that I can not open So I think the first thing I need help with is to open a bin file and then the best down load for my reciver. Please Help. Barry"
DO you have an autoroll bin?
Username: Barryh
I think so
doo doo
you will have to enter keys manually even with the new autoroll bins for now. and dont forget to go to channel 300 of dish network, when you turn it back on,
Username: Barryh
Where do i enter codes?
I do some kind of scan I get 200 or so chanles
but nothing comes in except the dish network help chanles.
Please help.
buffalo
How to change Dishnet keys: 00 or 01
Pansat receivers................
press menu
go down to parental controls, and press OK
press down arrow and enter 0000 thats 4 zeros
now go down to nagravision and press ok
now press the right side arrow next to the ok button 11 times until it says dish network
now press the down arrow 1 time
key number should read 00 now
using the buttons on the remote (number buttons, To type the letters into the new keydata, press the appropriate button on your remote: Audio = A, Info = B, Signal = C, Pause = D, Sat = E, EPG = F)
set the key to whatever the latest key code is
8A C4 96 93 EC 79 9D 57 ....(example only)
now press the ok button!
then press exit 3x to exit the menu
Lastly, on BACK of receiver (not remote)..power OFF,wait 1 minute ,power ON..this is a reset
This is how to change your public keys when needed, these instructions should work for both 2300 and 2500 pansats.
Fortec key change method
1)With receiver hooked up to TV and satellite:
2)Press MENU on the remote control
3)Then right side arrow to CHANNEL EDIT
4)Go down to CODE, and press OK, and enter 1010 (could also be 1668 or 1688)
5)Then right side arrow to turn OFF, KEYCODE FUNCTION
6)Go to NAGRAVISION and press OK
7)Now press the right side arrow next to the OK button 11 times until it says ((DISH NETWORK))
8)Go down to KEY Number, then right side arrow to set to "00".
9)Go down to Key Data and enter the latest KEY with your remote control.
D5 6F BB 83 00 D8 B0 4E ...(example only)
10)Press OK, "you will see the STORE button blinking, when it stop you know that KEY Number "00" is saved.
11)Go up to the Key and Go to the right "1 time" (that will change key 00 to 01
12)Go Down and enter latest Key 01 change ..11 B1 AA A7 8B 9E 45 8B (example only)
13)Press OK, "you will see the STORE button blinking, when it stop you know that KEY Number "01" is saved.
14)Press EXIT once.
15)Then right side arrow to turn Code back "ON" and enter "1668" then EXIT, EXIT.
16)Lastly, on BACK of receiver (not remote)..power OFF,wait 1 minute ,power ON..this is a reset
Fortec buttons to use for letters
Sat=a
info=b
tv/radio=c
pause=d
?=e
