To get 119 channels, can i get 119 LNB?
Username: Convidence
Post Number: 9
mine one is 110. I can't pick more Dishnet channels. I don't like 110 that much. There are less good channels to watch.
Username: Thechiz2
Mars, Ur anis Mine
Post Number: 39
move ur dish to get 119 then
Better yet, add another dish and a 22kHz
switch or a 2x1 diseqc. Then you
can have both sats working for you.
Username: Bootlegger
Post Number: 128
You can make a PoorMans dish to pickup 110, 119 very easily.I've been going that way for over a year. Boots
Post Number: 129
Bon, don't uderstand your thinking of sat 110, their are over 250 channels you can receive there. All the ppv's, some movie's. an much more. Your IRD must not be set up properly.Boots
Post Number: 130
Upload This is a picture of a PoorMans dish 110 is in the middle with 119 straped to the right slightly higher( facing the dish) than 100. using a Diseqc switch, to switch back an forth between them. Boots
Username: Thechiz2
Mars, Ur anis Mine
Post Number: 50
not to be a smart a*s but cool r u from the south
Username: Slo_hand2
Post Number: 9
boots very unique way liked the idea
Post Number: 131
It, works. set up over 30 of them just like that.cheap way to do 2 sats with one dish. an yes I'm from the south. But if you do your homework there is all kinds of ways to set up dishes.This is a weel know setup seen on many forum sites. try it you'll like it. Boots
Post Number: 132
Upload This is also a great setup, did it for a friend a few months ago. Notice the tupperware. lol. It's to protect the switch and connections. that was his idea. Boots
Post Number: 16
thx for showing me the picture so that I could understand how to do it.
Where would 119 be if I am currently picking up 110 with a dishpro lbn and dish 500 dish?
Username: P2b
Post Number: 17
119 info
[link removed]
http://www.tivocommunity.com/tivo-vb/showthread.php?t=246416
http://www.sadoun.com/Sat/Installation/Satellite-Heading-Calculator.htm
HTH
The P2b
Username: Maple_leaf
Post Number: 490
9 degress right of 110 and up 1 or 2 degress.
MapleLeaf would the 9degrees and 2degrees up also work with the dishpro and a dish500 dish?
Post Number: 498
yes the sat is still there.
A dish 500 has 2 lnb's one for 110 and the other for 119.
Chicago
Just who is this internet Conan tough guy who needs to be bich slapped... Go Away!...U are UNWANTED!...U must be Kneegrow!
Help....
Everything was running fine but suddenly my receiver went blank. I see full quality and signal but no channels.
I tried new bin with new channel list on my Lifetime Ultra. Did this ever happen to anyone and how to solve it? I rechecked the Key and they are correct.
What do I need to do?
Where can I find changing TP? I lost the file with changes.
thanks.
chicago
try a reboot/reset of receiver...BACK of receiver,power OFF,wait 2 minutes,power ON,turn to channel 300
Username: Prettyboy
my problem is currently using a sat finder device to look for sat 119, I;m using dishnet pro 500 i get a string beep fomm my sat finder but no signal to my receiver.
Can anyone help.
steve123454
i have a dish 500 i can get 110 but i cannot get sat 119 should i move the dish aropund looking for 119 or will i lose sat 110
uptown1864
I would like to know if the encore western channel has gone Nagra 2. I can not get that channel on the dish network system.
Salmerin
What to do if the only signal you get on SAT 119 are the spotbeams? I have tried TP 19,21 but get nothing and just for the hell of it I switch to TP 1 and 2 and I got Spotbeams with SS of 80 and up. Any suggestion as to where should move the dish when it is on the SB?
