Bell Express Vu Emulation
Soprano2223
I just started looking into this, i got the whole set up with the AVR hook up with cables to the computer, I'm going to use JavaEmu to start it up, but before i was wndering i keep on getting 019 error (card not inserted correctly) is this going to cause me trouble or when I do the javaEmu will it go away, or is there something i can check or do to get rid of this error, any answer backs would be appreciated, peace
Stbone
error screen will go away after you start the emu
