New Keys???????
BeltMann
Hey! Does anyone have the new keys??? PLEASE and THANK YOU!!!!! Byee..
Username: Dimples71
Key 00
B3 E1 DF 37 53 75 8A B5
Username: Cuco96
Post Number: 10
anyone with fortec new codes (key 01)?????? ASAP.. thankx...
Username: Cuco96
Post Number: 11
hey in.. need of the second key .. i put in key 00 but now i need key 01 in order for it to work.. plz help? plz plz:-(
Username: Cuco96
Post Number: 12
HELP
Username: Tomcruise
Post Number: 8
Key 0 : B3 E1 DF 37 53 75 8A B5 (changed Mar/22)
Key 1 : 0B 51 9E B7 EB 20 E7 4D (changed Mar/17)
OMARR1
here are the new key codes 3/22/05
KEY 00
LETS ALL HELP EACH OTHER AND REMEMBER TO POST
NEW KEY AS YOU GET IT TO HELP OTHERS
THANKS
raed aka
this key does not work....
Username: Cougar
These keys are not working. Anybody has keys that work?
a friend of LK
3-22-05 Dishnetwork rolled keys again... Key 00 is now the active key and it is as follows
Key 00=B3 E1 DF 37 53 75 8A B5
Key 01=0B 51 9E B7 EB 20 E7 4D
BTW keys are for dishnetwork..the FTA receiver pansat,fortec...its all the same keys...receiver make/model doesn't matter...U just input them differently.which is posted 1000x here in these forums...If U want to have these FTA "toys" learn the basics..
Username: Newark
I inputed the latest keys but it is not working for me. Does anyone know what I have to do????
Boston
KEY00 CHANGE
How to fix:
press menu
go down to parental controls, and press OK
press down arrow and enter 0000 thats 4 zeros
now go down to nagravision and press ok
now press the right side arrow next to the ok button 11 times until it says dish network
now press the down arrow 1 time
key number should read 00 now
using the buttons on the remote (number buttons, To type the letters into the new keydata, press the appropriate button on your remote: Audio = A, Info = B, Signal = C, Pause = D, Sat = E, EPG = F)
set the key to whatever the latest key code is
now press the ok button!
then press exit 3x to exit the menu
Now reset the receiver..Power OFF back of receiver,wait 1 minute,power ON
This is how to change your public keys when needed, these instructions should work for both 2300 and 2500 pansats.
FOR FORTEC ULTRA:
Press MENU on the remote control
Then right side arrow to CHANNEL EDIT
Go down to CODE, and press OK, and enter 1010 (Could also be 1668 or 1688)
Then right side arrow to turn OFF, KEYCODE FUNCTION
Go down to NAGRAVISION and press OK
Now press the right side arrow next to the OK button 11 times until it says DISH NETWORK
Go down to KEY NUMBER, change to 00
Enter the following KEY with your remote control (enter latest key code)
Now press OK,
Now press EXIT once
Then right side arrow and enter 1668, this will turn ON, KEYCODE FUNCTION
Then press EXIT twice to turn off the on screen menu and you are finished, and ready to watch TV.
Fortec buttons to use for letters
Sat=a
info=b
tv/radio=c
pause=d
?=e
Username: Newark
Thanks Boston - It worked...
Username: Newark
Post Number: 7
how do I get to have the movie titles appear?
My box is down for a few days, Key 00=B3 E1 DF 37 53 75 8A B5 does not work!! Any ideas?? Thanks
Username: Jmill1948
Chester, Va Usa
Post Number: 576
New KEY :
00
B3 E1 DF 37 53 75 8A B5 are he keys make sure you hold the ok button till it blinks 3 times
Username: Said
Saint louis, Mo Usa
hi i lost my indian channals doas somody can help me please i lost this channals> sun tv.set.gemni,
surya thank you
who needs keys?
These are the latest firmware for pansat with auto roll.
X-75BL_050314_236cE_api for pansat 2300A
X-85BL_050405_246_api for pansat 2500A
X-85BL2_050330_245_api for pansat 1500A
X-87BL_050315_101_api for pansat 2700A
X-95BL_3032_2005_0405_api for pansat 5000HC
they all autoroll. you don't have to deal with entering key changes again.
download the files free here
http://www.dsscentral.net/cgi-bin/hubblegram/CSUpload.cgi?command=viewupload&database=files%2edb
is there any autoroll key codes for the fortec ultra
Bosox
its a hard pill to swallow.....
but unfortunately sometimes the bad guys win......
you just cant compete with the owner of the bats and balls.......
best thing to do is an "honorable retreat"......
it was fun while it lasted....
I needed some vacations anyway.
bye-bye and good luck
Bosox
Knick Gar
Shane, Shane...Er I mean LK, LK, please come back!!!!
new keys 01 f1 74 32 95 f7 38 7d f0
new keys 01 1F 74 32 95 F7 38 7D F0
Username: Knee_grows_back
Post Number: 529
Yea come back LK...we miss you so much..Bo Ho, Bo Ho. What a bunch of azz kissing in here.....Who the Fucks gives a shiat if he leaves or not...he makes more money over att dssazzcommunity anyway..ROTF
go to bevkeys.com for the download to getkeys, the program that gets your new keys instantly.
Header108
new Keys for 4-14-05
Key00
79-B9-9D-5E-E6-BE-E7-60
Header108
IGNORE KNEEGROW......ITS THE ONLY WAY
LK
Keymaster is even better...it has more additional features such as dish point angle calculators etc..along with the immediate new Keys whenever they change..www.dsscommunity.c*m has it in the File Share FTA area..
This site (Ecoustics) now has banned the word "dsscommunity.c o m"...so thats why the c*m instead of the .com
LK
Posted on Friday, April 15, 2005 - 10:17 am:
Also Keymaster gives U BOTH Dishnet and Bev keys...but so does Getkeys...using an AUTOROLL bin is even better than using either one of these key finder programs..the autorolls and how to install are there too..its very simple.
look no more
just go to http://www.dssevolution.com/forums/index.php? new keys ALWAYS posted on right hand side of screen, no need to look or ask.
LK
look no more...U still have to connect to a website at heavy traffic times and probably wouldn't get connected...what U are saying is actually hurting all the testers here..every website has the key changes posted...U are not doing anyone any favors here..
Everyone should either get the very simple software (getkeys or keymaster) and download it ONCE to their computers and then U WILL ALWAYS have the newest changed latest keys on hand on your computer desktop or anywhere U want in your computer (then manually input the new keys) without ANY need to go to ANY website EVER!...or better even to use an AUTOROLL bin,which changes the keys in your receiver automatically,and U don't ever have to search for, or even know what the newest keys are....
martin
