Sorry, I assumed DN is the only FTA capable network. Anyway, on Dishnetwork, I used get Channel 610 (SunTV) fine until around Mar 9. This happened beteen the key changes. From then on I get only a blank screen even though my signal strength is green. By getting the channel but not a/v, I am assuming the current Nagravision is not able to descramble this channel. Is it possible the second key is kind of not perfect? I have Spacestar DVB500. Anyhelp is appreciated, Thanks.
Its Just starting
Peeps are starting to loose channels like 120 and 160. Shiit is starting to pour !!
LK
geek....either do a rescan of your FTA (which U never mentioned U had)or Nagra2 has taken the channel..its NOT the key changes were done wrong..
geekki
I did rescan, reboot, switch off the receiver for few hours, reset to factory default, etc..., but no avail. I am getting all the other channels fine, including 120 & 160. I think Nagra2 has shown its face on South Asian channels first. ps. I am the same geek here. I forgot my pwd.
