Connect dvr/vhs deck to dvr to tv line
Username: Angeleno
This should be simple: I'd like to get a dvr deck that records at least 2 shows at once, AND has an input jack to plug in my old dvd/vhs deck, so I can replay old tapes and discs through the same line that goes to the tv from the dvr deck. Nobody around where I live knows if such a dvr deck even exists, including (of course) the Comcast people (duh!). Any help really appreciated.
Username: Ieee488
Post Number: 625
I don't know why having that input jack is so important.
TVs these days have a gazillion inputs.
As for recording two shows at once, you can do this only if the DVR has dual tuners and only if the signal coming from your cable provider is unscrambled.
Username: Angeleno
TV has only one input line. need to merge feeds at some point.
Username: Ieee488
Post Number: 626
"merge" feeds?
not going to happen
the inputs are not pass through to the output
I suggest getting a device from Radio Shack that lets you select from 2 or 3 or 4 inputs
I used to use one when I had an older TV
Username: Angeleno
Radio Shack device no good--only RCA plugs.
Need to Register?
Forgot Password?
Enable HTML code in message
