How to disable Smartlock on Magnavox Smart Series
Username: Teach26
Here is my problem in a nutshell. Bought this TV second hand for great deal. However someone had already entered the Access Code for the Smartlock on my TV. Is there anyway I can disable their access code? It is irritating when watching a R movie I have to move movie to another TV set currently. Any help would be appreciated.
same as above
Username: Bmoyer
Surprise, AZ United States
Same problem, I don't know the four digit passcode to enable/disable smartlock---any ideas would be appreciated
Username: Gaka
same problem, I can't disable access code
Username: Teach26
Try using 0000 as your access code. Believe it or not it worked for mine.
