After the death of the HU and the forever wait for the p4 to be cracked. I am about to give in and buy the programming.Which really bites because I can't get locals where I am.....Anyway, If I were to buy a two room system and activate it at my home. Cant the other receiver be used in another house? If need be a phone line could be ran to the next house. It is next door (80acres away), but next door. Anyone tried this?
cali777
Yes you can do thatwithout any problems, just let them set up the systems then unplug either one & hook it up at the other house without the phone line plugged in, they will tell u that u need to keep them pligged in, but you dont..also if i were you & you are going to get the 2 room set up i would go for 3 room it's all the same Free installation & then you will have an extra card & ird when the fix does come out...
