ZTE U880 (Variant Of Blade) android 4.0, Supports T-CDMA?
Username: Jessicasiny
I found a ZTE U880 Android 4.0 Cellphone with GPS for $183.99. I think it's a good price with this specifications.
CPU Marvell PXA920, 806MHz
Main Screen 3.5 Inch Capacitive
Network Band 2G GSM 850/900/1800/1900; 3G TD-SCDMA 1880-1920/2010-2025MHz
Camera 5.00Mp
Support 3G,Java,WIFI,GPS,A-GPS,G-Sensor,Light Sensor,ProximitySensor,Bluetooth,GPRS,CMMB TV,Mp3,Mp4,SMS,MMS,WAP,Voice recorder,Radio,Alarm,Galendar,Calculator,Memo,E-book
How do you think this phone? It really runs android 4.0? Dose anyone have this phone? Or is it worth to buy? Thanks for help!
Username: Project6
Post Number: 16157
Incorrect. I used that phone for a little and it sucked. The touch screen is buggy and will not respond promptly to touch. You need to finger bang that stupid phone, hard, for it to respond. Maybe it needs to be done to you as well to get you to stop spamming this site with your crappy product.
Need to Register?
Forgot Password?
Enable HTML code in message
