Changing cell phones
Username: Trackster1991
Post Number: 98
i am thinking about buy a cell phone off ebay. If i bought a phone off ebay could i take the sim card out of my old phone to make the new one work?
Username: Ftalife
Post Number: 109
if its the same model phone
Username: Ftalife
Post Number: 110
i would switch my sims on my nextel and it was fine.
Username: Ftalife
Post Number: 111
but, i don't know if its the same with other phones
Username: Nassa
Post Number: 50
Harry yes you can if it has a sim port, but you have to make sure it is unlocked and can work with your band. Quad band phones are the best.. If it is unlocked and a quad band then your good anywhere in the world
Username: Ustaad_hc
Post Number: 392
motorola razr2 v9 is the best phone in the market.
Need to Register?
Forgot Password?
Enable HTML code in message
