RCA Lyra RD2762: File System Corrupt.
Username: Xxpigxx
Hello. I have been going through these threads, but I have a problem that has not ben addressed.
My brother gave me his RCA Lyra RD2762, with the installation CD. I installed the Lyra application, and tried to run it, but it does not show in the system tray, although it shows as a process when I chech with alt+ctrl+del. Therefore, I cannot upgrade the firmware, which sucks because I get the File system corrupt message. I can get the icon to show by ending explorer.exe and starting it again. But when I right click, all the menu options are grayed out, and the icon disappears.
The player does not show in My Computer as a drive, and it will only play the USB sound if I hold the control stick on the player while plugging in the USB cable. WHat's more . . . it goes to the transfer screen, but 10 seconds later, it shows the safe to disconnect message, without any prompting fromn me.
Can someone please help me?
Thank you.
Username: Jrharden
I'm having the exact same problem...it's hard to fix it when your computer wont even read it...
