Mpio fl600 trouble
Username: Pinodel
I purchased a MPIO FL600 as a Christmas present
for my wife. The set up was smooth, and my wife easily created her
own
playlists. It sounds like the FL600 has similar problems to other
mpio players.
When I tried to make my own playlist, I filled the gig, and then
the player
froze up. I turned it off and when I turned it back on it just
said "please
wait". I waited and eventually it went to the root directory. There
were many
files represented by different symbols and/or languages (ex.
>@p8!. ) "My
list" and "record" are also there but they do not work.
I tried following the directions in the adobe file using the
mpio utility to
format the player, but I ended up with the same result. I can still
drag and
drop files into the player, and my PC will recognize the player. My
PC however
will not recognize the .smx files. I simply can't get back to the
default
settings. The FAQ on the website does not help, the new firmware,
and the adobe file does not
help me either.
I went back to the store (Future Shop, the canadian version of
circuit city)) and the clerk had never experienced a
similar problem. Any help would be greatly appreciated. Thank you
for your
time.
Peter Halford
