Logik 1GB MP3/WMA Player
I bought the Logik MP3 IGB LCD Player as an Xmas present for my daughter - She loaded about 500MB worth of WMA's and then found that she was unable to load any more (Message says "Cannot copy <filename>: The directory or file cannot be created") - All music files have been created in root (ie no sub directories have been used) - Properties definitely show the disk space to be only half full - What can we do to fix this please?
We didn't format the device before using it, which I think is the problem - I now believe it is necessary to reformat the device, to see it's full size, however if I do, will it overwrite any files necessary to it's proper working, or are all the 'player files' hard coded into the device? - If there are necessary files on the drive and I should accidentally overwrite them where can I get copies of them from please?
