Ipod Mini Crashes Computer when Updates in Itunes
I really need help on my ipod mini. The main problem is that my ipod mini causes my computer to crash (blue screen) after the ipod update in itunes. it does it every time. itunes works fine besides this major problem. i have tried uninstalling and reinstalling both the ipod and itunes, but same problem. anyone know how i can fix it? I use XP professional. Thanks in advance.
Username: Illuminator
Post Number: 1357
What are the specs on your computer?
brand new dell laptop. 600m. 512 RAM. 60 GB HD.
parks
I have the same problem except with the new ipod. Apple says it is a software compatibility problem, but they never heard of this problem. By the way, my laptop is a dell xp professional too.
mr eon
Winamp has a plugin that will allow you to transfer
music to your Ipod. Thank God because my computer
kept rebooting when I would transfer files.
http://www.winamp.com/plugins/details.php?id=138888
