IPOD cable troubles
Username: Wagskater2005
I just bought a refurbished Ipod from apple. When trying to get my songs I noticed that there was no cord to connect from my ipod to the usb port. there was one that connected to the usb port and one that connected to the ipod but not to the other cable. I asked a friend at work and he said that they gave me a six pin adapter and a 4 pin adapter but we have an 8 pin port. Is there a caple i can buy to get it to work?
Username: Project6
Post Number: 3883
Are you talking about a firewire cable?
Look at the device manager in your system and check for IEEE 1394...this is your firewire.
Username: Project6
Post Number: 3884
If you have a usb port on your computer just get a usb connector. Let us get specific here and none of that 4 pin and pin adaptor stuff.
If you have a firewire port then you don't need another type of cable.
