GENX 2GB music key problem...
Username: Slow86
Hi..
My name is Umair and i had bought my musci key which 2 GB and at first it was working perfecty...but after some time it has stopped working...First i thought that it was battery problem but after changing thre battery packs it still wont work..The usb works but when want to listen to my songs it doesn't turn on...i had recently updated my firmware but nothing happened...pls help
Username: Project6
Post Number: 14358
Have you tried their tech support?
Username: Slow86
i have posted the problem there also but didnt get any response as of rite now...
Username: Project6
Post Number: 14388
That should tell you the level of quality of your MP3 player. How old is the player?
Username: Slow86
just bought it 8 months ago..can u help...plz
