Problem,B&K PT3 Series II Preamp
Username: Kegger
Post Number: 52
it seems to have a problem i will quadruple check it before i condem it.
maybe you are familiar with the symptoms i am having.
there are three preamp outs on this unit, a high output 80hz on up, a low output from 80hz on down and a full range out.
i am getting the same frequency from all outputs (full range).
even if i come out of the sub outs(80hz on down) then go into my 2 channel amp out to my speakers i stell get the full range of frequencies.
and i can verify this with my analyzer.
now this unit has a factory reset which i haven't tried yet but i will.
any ideas , have you seen this before?
any comments are welcome.
