SOURCE DIRECT and when to use it?
Username: Stifa
Post Number: 14
I have Marantz SR6300 receiver and BW 601 S3 speakers with a shitty CD player connected to receiver via RCA interconnects(analogue).
Since I can't hear difference with the SOURCE-DIRECT button ON and OFF I ask you good people what is the use of it?
Is it for players connected digitally or WHAT else?
Thanks
Marko stifa@eunet.yu
Username: Myrantz
Post Number: 780
If your cd player has either an optical or coaxial digital output, then try hooking it up to one of the recievers digital inputs; therefore using the receivers DAC's. I did this with my SR-7300 and an average Yamaha cd changer and it made a world of difference soundwise - especially using the source direct mode.
