PSB Centers
Username: Jasond
I am yet another victim of a low WAF. Not only do I have to get bookshelf speakers, but I don't have a lot of vertical space available.
I am very partial to PSB's, and was wondering if there is any reason I can't use two Image 9C's as fronts with an 8C.
I welcome any opinions, and this money is burning a hole in my pocket.
Username: Myrantz
Post Number: 597
I don't know about the PSB's but the B&W LCR600 series 3 or LCR60 series3 might be worth considering as they are designed for vertical or horizontal placement as well as for use as either center, main, or surround speakers.
Username: Landroval
Post Number: 571
Vertical placement is usually better because it doesn't cause comb-filter problems with a d'appolito speaker. If you have to place your speakers horizontally it would be best to get three identical 2-way bookshelf speakers and put them laying on their sides. But if you still go with three centers I suggest you take three identical speakers and not a smaller center, this way the front soundfield will be as uniform as it can.
