Help using pioneer vsx-912 receiver
Username: Shamusss
i've just purchased the vsx-912 receiver and am having problems getting the dts to work, not to mention the digital decoding symbol does not appear. I have connect the receiver to my dvd player by optical cable for audio, and regular cable for video. The dvd player is JVC XV-M555 that i have had for awhile. It is supposed to give dts out. either way no digitial decoding symbol shows up when dvd is playing!! which i would automatically expect -- when have selected standard .... can anybody help??
Username: Shamusss
futher, when i select the dts option by the dvd player while the movie is playing, then select standard to get the dts option --- the dts encoding symbol doesn't appear, the dolby digital symbol does not appear, and their is no sound at all while the movie is playing in dts sound format....!?!?!?
Username: Shamusss
ignore the above, problem solved
