External amplifying 7.1 reciever, amp suggestions
Username: Kegger
i have an hk525 reciever with all channels driven
and i'd like to preamp out to all channels.i have
all the extra speakers allready.
i allready have 1 2channel(200watts a channel)amp
so i would like to purchase a 5 channel amp preferably with adjustable gains(but not a must)
and somewhere around 150x5 channels.(able to drive
4ohm would be nice)
budget would be $1000 or under i'm sure i could not get anything descent for around $500 but that
would be really nice.(maybe older model)
i know some of you will shun the idea but i like to tinker and will be powering half the basement
20x30 with 8 foot ceiling.
i am running 8 12" sub's 2 powered on the center channel and 6 powered by 200 watt amps.
needless to say i use the system mostly for movies
and when i want it really loud i can turn on the
second set of 7.1 speakers.
like i said i know this is not conventional but i
have been colleting speakers and amps for a while
and would like to experiment some more.
thanks for any help in this endevor!
Username: Gman
Post Number: 14
Outlaw Audio has a great 200 x 5 amp for $1299. Adcom has the GFA7605 125 watts x 5 for $795 at reliable audio and GFA7700 175 watts x 5 at $1189.
Also NAD 925THX 125 watts x 5 at $989.
You can always sign on to audiogon.com and poke around for used 5-channel amps.
Username: Kegger
thanks gman
what about the marantz mm9000
or the anthem mca 5
either one these any good? or descent price.
or others are still welcome!
Username: Kegger
Post Number: 7
i just got back from doing some shopping and 1 place i went gave me a price on 2 amps.
the parasound 855a i know it's only 85x5 but $500
out the door.
or the marantz mm9000 for $700 plus tax.
any thoghts on either one of these.
Username: Heff
These guys had the Adcom 7700 for $900 a while back, and now they have the Marantz MM9000 delivered for $699.99.
While it's nice to have a local source to hear what's out there, it's also nice to be able to purchase from authorized internet dealers too.
Save some $$$ b/c Christmas is coming!
Reseller rating for Accessories4Less --> http://www.resellerratings.com/seller2923.html
Username: Gman
Post Number: 18
If you are experimenting, try Outlaw Audio's mono channel 200 watt amps. I think they are $299 each and I know they used to have a deal if you bought 4 they threw in the 5th.
Or you can try looking at Audiogon.com and looking for used amps that have the capabilities that you are looking for.
