Does anyone know of any good sites to buy....
Username: Rezistance
does anyone know of any good sites to buy mission subwoofers? I have already been to the likely sites such as ebay and richersounds but was wondering are there any other. A combination of sites offering new and second hand subwoofers would be a great help.
Mny thanx
http://www.audiogon.com
Username: Valeem
Post Number: 145
You mention richersounds so you are likely from the UK. These are some I have come across and they are competitive but only sell new subs.
http://www.hificonfidential.co.uk/
http://www.prcdirect.co.uk/PRC/PRC.storefront
http://www.empiredirect.co.uk/index.asp
http://www.superfi.co.uk/index.cfm (This one seems a bit pricey at first but they will price match)
It's not Mission but this may be of interest to you. I believe they could also be releasing another batch of the Ruark Log Rhythm for £250 but you will need to contact them to clarify the situation. Buying direct from the manufacturer gets you much more value for your money.
http://www.bkelec.com/
If you do a search at the forum below all will be revealed.
http://www.avforums.com/
