Archive through August 01, 2004
Closed: New threads not accepted on this page
  Thread Last Poster Posts Last Post
KLH Subwoofersneal m4
Definitive Technology Supercube Reference?Al Holland5
Need Advice-Paradigm SubsAnonymous11
Multichannel means no LFE Sub track?KEGGER3
OHM LOAD HELPPeter Galbraith2
Help Me Decideneal m14
The difference.Peter Galbraith2
Klipsch RW-8 or Canton AS 20 ?Anonymous3
Hmmmmm sound in subwoofer..KEGGER2
Hsu stf-1 versus stf-2 - worth the $100?Don Kelly1
Is polk psw202subwoofer correct for my room size and av receivershank3
Problem with Rear R outputEric Pisanko2
Any web for learning the placement of sub.........J. Vigne2
Rca 125 watt subEric Pisanko1
I like rock, what kind of systme is best for it?likes rock1
How to connect my RCA Input Sub to my Receiver!! Skial1235
Connecting subwoofer to "digital ready" ampBrian Goldschmidt1
Velodyne CHT-8 cutting in and outSteve D1
Sub set upcornboy1
Klipsch RW-8 or Canton AS 20 ?Anonymous1
I NEED HELPfletcherreede6
Subwoofer placement... suresh babu1
Help me choose sub: PS1000, ASW100, or Better??Anonymous3
Venturer av100 sub upgrade?Lester Ferguson2
Using 5 ohms 250watts sub.with 100 watts 8 ohms receiver.suresh babu4
Sub placement debunkedStan Bodnar2
Power problem in sub..suresh babu5
Sub recommendationsMy Rantz2
Help! Can't extract toy-blocks from subwooferKEGGER2
JBL E250P subwooferAnonymous2
Passive Subs- aside from SVS, any others out there?Brock Frederickson1
Buzzy subwoofer replacement speakerdwsw4
Trying to find a speaker boxGrizzly2
Sony SubwooferKyle Berg5
Energy ES8 replace or not?newbie4
Home Subwoofer LFE vs Line in hockups???Gregor5
Insufficient cable connection to subwoofer david stier1
Kenwood submak2031
ProblemJoseph Martin3
Looking for powered subalbaro3
Lookin' for a SubJimvm12
ProblemJoseph Martin1
Equalizer??Dan Reid1
Mirage BPS400 Dual 12" Subwooferpower-ranger4
Subwoofer ConnectionsTom V.2
Subwoofer at fault?Tom V.12
Converting subs for PC useRed Rick3
Subs - Boxed, Ported or Inverted???Neal6
HMMM FLUANCE?Matt Haug3
B&W DM601 s3 + SUB or DM 602 s3 ??Gregor3
Would you please let me know if this passive subwoofer with this co...Sundeep V Menon1
Any opinions on Yamaha YSW-215?/ ADVICE on SUB under $300??Marko Stijelja1
Are the Atlantic Tech Subs worth gettingkingtut2
Crazy Talk! Random skreetch from RCA SubErik Mayo1
NHT SubsBerny3
Volfenhag 12"ryan knoll2
Help with Subwoofers and AmpsLeelan6
Velodyne CHT-10 vs. Hsu STF-1Mr. Speeed7
1 big sub? or 2 small subseric belanger3
Adire Tempest with 2 15" PR or 2 4" portsJeffKnob1
Buzzing subwoofernick anderson4
Self-Powered Subwoofer vs Non-Powered (Passive ?) SubwooferKEGGER5
Any reccomendations for subs under 7?Sumguy1
I have everything you are looking for for great prices!!!!Berny2
W7 need a tipAnonymous2
Mainstream subs?Anonymous3
Mysterious Subwoofer Dilemajack belton2
Active sub to car amp?jack belton1
James SubwoofersJackson51
Best sub for under $700Brandon Konran4
SubwoofersBrandon Konran3
Rel stygian? mark goves13
Best small sub???huntergriffin26
New car wnat lound and SQ systemsdfjkop4
Athena asp400? or better for same $toto fabella3
What can I buy for 300 dollars without going to ebay?toto fabella1
Better sub than SVS PB2-ISDNathan Morrow4
Radio Interference with PSB Subsonic 5i subwooferStuart Garrett1
Which connection?Poo5
1st time subwoofer buyer looking for helpBrandon Konran9
Subwoofer directly to TV?Anonymous3
Y- Connector on Subwoofers???? Pleae help..............Scot B9
Hook up car amp to computer or TVJZsnowboardalot1
Memphis LVS subsmojo_1603
Help With Dual 4ohm Voice CoilKEGGER4
Wiring up subwoofer????????J. Vigne3
Car Audio Sub to Computer or Home StereoLicence2ill1
Subwoofer cable?ABC3
Help in Setting Up / Calibrating my Inifinity SpeakersStray2
Infinity SubwooferEric Bundy6
Hmm any one know whats wrong?My Rantz2
Ohm Problemriffraff7772
No Sound from SubJ. Vigne11
Dual tens in a box for home theatreNathan Morrow2
Subwoofer ThumpingKEGGER8
MTX Subs in Home Stereo CabinetsNathan Morrow3
My DIY home sub.Nathan Morrow3
Can anyone tell me?Gary Moore1
Crossover buildNathan Morrow2
Single Sub output/dual inputNathan Morrow2
