Bose SA2 amp connection to Bose Lifestyle 5
Username: Johncburgess
Hi,
Does anyone know where to get the '3 ft Audio Input Adapter cable' shown in the attached image for interfacing the Bose Lifestyle 5 to the SA2 amp via the Bose Link A cable? My local Bose agent staff were all only babies when the Lifestyle 5 was released & have no idea.
Alternatively can anyone who has one of these cables bell it out end to end so I can make one up?
Username: Davidg1974
I have a power amp that goes with one of those but no receiver foreground component. I bet they sound killer cause it weighs a ton and has a sub -woofer built in with it and bass and treble knobs on the side? Anyway connector you are looking for is an 8 pin DIN connector. Probably have to order one online unless u have a radio shack or we'll stocked audio or music store local. Need to get one for the one I have so I can try it out. Good Luck!
Username: Chrischrisbryantconz
Hi there, need to do this exact same thing myself! There are few of these cables on ebay but just checking this needs to be 8 pin? The input on the SA-2 amp is 9 pin? Will this work?
Need to Register?
Forgot Password?
Enable HTML code in message
