Technics RS X320 Double Tape deck with no power source
Username: 123brianm
I have problem, I purchase Technics RS X320 Double Tape deck with no power source except its conventional amp to power it as it didn't have a dedicated power source. Is there an AC DC adaptor or RCA Lead I can use to power up my tape deck to work? Please can you supply website of product I can use to purchase via Ebay or Amazon.
Username: Magfan
Post Number: 3615
Find a copy of the schematic and see what is required AND the wiring connector, if possible.
You might be able to find a 'phantom' PS which will allow the deck to function.
I can't believe that ANY reputible company did this.....but here it is.....
Need to Register?
Forgot Password?
Enable HTML code in message
