2.1 setup in basement
Username: Unbridled_id
ChicagoUsa
Post Number: 757
ok...so around black friday time I was going to purchase a new amp to hookup to my tv.
Basement tv room and simply want a 2.1 setup. Have a dvd player and stream tv as well. Have def Q 100's and posted
on the sub forum regarding the emo subs.
Want to go with the NAD c328 as it's simplicity seems to fit the bill. Was also considering the Onkyo 9150, and wondered if anybody here has
heard either of these two amps ????
Username: Jan_b_vigne
Dallas, TX
Post Number: 18578
Buy the Onkyo, it's easier to get fixed.
Username: Magfan
Post Number: 3499
Another possible choice would be Emotiva.
They make an inexpensive receiver and if you want to buy an amp, a tuner-preamp, as well.
For a PREMIUM 2-channel receiver (receiver includes FM tuner) the OutLaw RR2160 would be a good, longlasting choice.
ChicagoUsa
Post Number: 758
Jan... why do you say the Onkyo is easier to get fixed ?
Saw this article on the onkyo
https://www.intl.onkyo.com/a-9150/
Dallas, TX
Post Number: 18579
NAD has always been more of a PITA to get fixed.
The Outlaw is a good choice for 2 channel. It has a dedicated subwoofer out.
ChicagoUsa
Post Number: 759
Thank you Jan. The outlaw is out of my price range. It really is between
The nad c328, onkyo 9150, or the Yamaha 501.
Dallas, TX
Post Number: 18580
Buy the Onkyo - or a used/refurbed Outlaw.
Username: Magfan
Post Number: 3500
'b' stock Outlaw doesn't save THAT much $$$. Unfortunately.
I'd be thinking more long-term value and thinking the Outlaw will be around after you are done with the NAD, Onkyo or Yamaha.
I can see the Outlaw ending up as a 2nd or 3rd room system 'center'.
Dallas, TX
Post Number: 18581
I'd be thinking the Outlaw will still be worth the same in five years as it is today because it will still be working.
Username: Magfan
Post Number: 3501
For Pete's Sake, Jan, we're gonna have to stop Agreeing.
You bet. Outlaw should retain value very well indeed. It's prior model, the RR2150 was made for maybe 8 or 10 years essentially unchanged.
Even a change in factory where it was made, and a subsequent Stereophile RETEST didn't change anyones generally good opinion.
If this were 'Consumer Reports', it'd be a 'best buy'.
Username: Fertooos
Fratees, Aklan Филипп...
Post Number: 12
Need to Register?
Forgot Password?
Enable HTML code in message
