Marantz pm7003 + Infinity primus 250
Username: Qw11
Hi Guys,
I'm using Marantz pm7003 amplifier paired with Infinity primus 250 speakers. Going above 85% of the volume knob the lows are becoming weaker the sound is distorted and sometimes the protective circuit is triggered. Why is this happening? Should i look for new amp or new speakers?
Username: Jan_b_vigne
Dallas, TX
Post Number: 18507
The amp is going into clipping; https://www.google.com/search?q=what+is+amplifier+clippling+distortion&rlz=1CAAC AY_enUS754US756&oq=what+is+amplifier+clippling+distortion&aqs=chrome..69i57.1449 9j0j1&sourceid=chrome&ie=UTF-8
Bass requires more power than the upper frequencies and your volume control is not linear. Output for any setting on the control is relative to the input level from the source. So 85% on the VC is almost always too high. Turn down the control or risk blowing out your speakers.
Doubling wattage - all else equal, which it never is - will only gain you an additional 3dB on peaks, not at average level settings. To play louder without driving the amp into clipping requires at least another +6dB of electrical sensitivity from the speaker system or 10 times the RMS wattage of your current amplifier. Additional speaker sensitivity will raise all frequencies (more or less, given the flatness of the response from each speaker being compared) and the music will sound louder with less rotation of the vc (using the same amplifier). The amp will be producing less wattage, be further away from clipping and the speakers will put more loudness into the room. All things being equal, which they never are.
Username: Qw11
Thank you very much for the great explanation.
I think i should consider replacing my old infinity's with KLIPSCH KF 28 which are rated at 98dB and can handle up to 150W RMS.
http://images.klipsch.com/Icon_KF28_Cut_Sheet_635042121963620000.pdf
Need to Register?
Forgot Password?
Enable HTML code in message
