Left and Right Studio Monitors in one jack?
Username: Aboutnow
Hey guys, it's my first time posting here so I hope this is the right subforum.
A friend of mine recently let me borrow his pair of M-Audio BX5s (https://www.amazon.ca/M-Audio-BX5-D2-Speakers-Pair/dp/B005F3H6Q8), but I'm having the most difficult time trying to get the left stereo information to play on the left speaker and the same for the right. I'm using a Xonar DGX sound card and according to the manual the left and right sound comes from one jack (manual: http://dlcdnet.asus.com/pub/ASUS/Audio_Card/Xonar_DGX/E11106_Xonar_DGX_UM_V5_web .pdf?_ga=1.95807578.776623969.1489279373). I've tried using a Y cable adapter, but this results in both speakers receiving both left and right stereo information on each speaker. This seems to also cause all the mono center sound to disappear, and this also happens if I only have one speaker connected to said left and right jack.
Is there some sort of adapter that let's me do what I'm looking for? My Y cable adapter is just one that I found in my box of cables and electronics so I'm not convinced that it's made for the job. If not, is there something I can do to fix this issue?
Thanks!
Username: Jan_b_vigne
Dallas, TX
Post Number: 18394
I can't get your link to work but, it sounds as if you are using a mono plug and inserting it into a stereo jack.
Username: Aboutnow
I think that may be the case. Here's the link the site where you can download the manual https://www.asus.com/us/Sound-Cards/Xonar_DGX/HelpDesk_Manual/. Is there anything I can do if that is the case?
Dallas, TX
Post Number: 18402
You can buy the correct cable/plug.
Need to Register?
Forgot Password?
Enable HTML code in message
