Alpine spe 6090 6×9 review
Username: Beatskart
Muzaffarpur, Bihar India
Alpine spe 6090 6×9 review: If you are looking for the great sound quality for your car then Alpine spe 6090 6×9 is the best option. This Speaker fulfils all your car’s requirement to rock the sound quality.
Note: If you don’t have time to read the full article then go through our pros and cons section, from there you can easily decide either you like this Alpine spe 6090 6×9 or not.
Alpine spe 6090 design for whom?
This Speaker is perfect for anyone who:-
Those who are not sure to install an amplifier.
Those who want quality Speaker at a reasonable price.
Those who want to change their factory speakers.
Those who want a full range speaker.
Those who want DIY install Speaker.
Those who want coaxial speakers.
Those who want deep bass.
Technical Specification :
Speaker size: 6×9 inch.
Speaker Type: 2-way
Sensitivity: 91dB
Impedance: 4 Ohms
Frequency Response: 65 â€" 18k Hz
RMS Watts: 75
Speaker Build Materials: polypropylene
Tweeter adjustment circuits : (0, +3 dB)
Item Weight: 9 pounds
Pros
Comes under decent price.
compatible with an amplifier
High base due to its high Sensitivity (91dB)
Compatible to the system
frequency Response of 65 â€" 18k Hz which is really good for deep bass
Attractive design that makes to install in your car easily.
Cons
RMS is 75 Watts which is quite low.
Impedance is also low that is only 4 ohms.
Gets a little buzzy with excessive and or long
https://beatskart.com/alpine-spe-6090-6x9-review/
Username: Jan_b_vigne
Dallas, TX
Post Number: 18641
This isn't the car audio forum.
What's so hard to understand about that?
Need to Register?
Forgot Password?
Enable HTML code in message
