Sherwood S 6020CP
Username: T_bass
North Platte, NE United States
Post Number: 12
Hey Guys,
The Volume up control button is stuck. You can use volume down button to lower the volume but as soon as you release it the volume maxes out again. Is this something that I can fix? Thanks
Username: Jan_b_vigne
Dallas, TX
Post Number: 18277
T-Bass, you really need to stop messing with all this old crap. You can buy a new VC and replace the defective VC. If you can't locate the new part and perform that repair on your own, you will need a shop's assistance. Rates should begin at about $60 per hour.
Need to Register?
Forgot Password?
Enable HTML code in message
