Philips cdr 820
Username: Sitnol
I just bought a refurbished philips cdr 820 audio cd recorder. When I put a blank disc in it reads 'wrong disc, insert an audio cd'. does anyone know which brands of Audio cd's will work, and will cd-rw's work even though it's not a cd-rw recorder?
Username: Jan_b_vigne
Dallas, TX
Post Number: 18103
Find the owner's manual on line. It will have a list of suggested recordable CD's. If the recorder is not set up to operate with a certain type of disc, then you can fairly well bet it won't.
Need to Register?
Forgot Password?
Enable HTML code in message
